Hi all! First post.
I've noticed that the headset bearings seat very loose in the frame. I'd say there is about 0.25mm of slop/gap between the frame and the bottom bearing cartridge. If I insert it dry (no lube), it will fall right out without any resistance whatsoever. Of course, when I actually install it, I apply lube - which will mostly hold it in place unless I shake the frame. Is this normal for the CAAD10? Is there a way to have a more snug fit?
I'm concerned the bearing assembly is migrating in the head tube while riding. I've had creaking, but I'm not 100% sure it's coming from this area.
