I recently built a Caad9 with Red and a Cannondale SL Compact cranksand a KMC chain,the only change from the Red was a Force front derailleur. I have set up 100's of bikes and never have run into the problem like I have now.
I have chain drops into the inside and outside and even setting the stops tighter, then I can not get the chain inti the big ring.
I am considering getting the Red front derailleur to see if that is the cure all. Any suggestions.... STARNUT...I need you!
