1 - 6 of 6 Posts
It's not needed. But shimano shifter cables wear out, and the 10sp shifters seem to wear the cables out faster than 9sp. So you should at least replace the inner wires. Since the shift cable housings are out in the open it only takes a few minutes to replace them too.
If you leave the brake housing under the bars make sure that the levers but up against the housing ends. If they don't the housing will be held in position only by tape, and it could move at any time. That'll increase the cable slack and possibly cause you to lose your braking.
Trying to thread a used, crimped cable through the shifter and housings can be one of the more maddening experiences of wrenching. Those little cable strands under the fingernails feel great!
Replace them. Takes the same amount of time (most likely less time) and costs just a couple bucks.
Cable condition
russotto said:
When going from 9 speed to 10 speed Shimano, is it necessary or advisable to change the shifter cables?
It really depends on the condition of your old cables/casings rather than the switch to 10s. If you have doubts, replace the cables/casings. Otherwise, no need.
· Steaming piles of opinion
That's why I don't use the crimps. I finish the ends of my cables with a drop of thick CA glue.
But really - yeah, go ahead and change 'em anyway.
1 - 6 of 6 Posts
