1 - 3 of 3 Posts
For the life of me I cannot get my new front der cable thru the "internal" routing in near the BB, that routes up to the front der. Not the external cable guides on the bottom shell, but the 2 little holes that are internal...Tried everything but it seems like it may have shifted inside and I cannot get the cable thru it...
Any Ideas? Cannot recall, but can I access that thru the BB to see there is a way to see that internal routing?
Any advice would be appreciated
Or music wire available at most hardware stores or hobby shops. I've had the inner tube get jammed up with grit preventing threading through a new cable through. I got a fine wire to poke through then used a bit larger wire and finally got it loosened up and cleaned out.
1 - 3 of 3 Posts
