I love this black on black. Very stealthy.:thumbsup:monofin said:Wow, already a couple of CAAD10 bikes here around.
Let’s start a CAAD 10 gallery.
i love mine:aureola:
With Yokozuna it wasn't so much a difference in shifting but the huge difference in braking. Before this build I had two different bike setups one with stock SRAM housings and other with Dura-Ace. The SRAM felt the worst out of all for brake feel, the brakes were very squishy unlike the Dura-Ace and Yokozuna which were firm with great feedback. One thing I didn't like about Yokozuna is that the brake housing is very thick and very hard to bend. I had to literary spend half an hour getting the housing length right (new build so nothing to compare it to) for front and rear brakes so that the springiness of the cable would not rotate the brake caliper causing it to rub the rim. Other than that I will most likely buy Yokozuna again because I love my brakes firm and responsive. Dura-Ace was very close 2nd, too bad they don't make them without the Dura-Ace stamps on the housing.CHL said:Hi niskyspy:
It looks like you're running Yokozuna cables and housings. Have you noticed any difference in the shifting and braking quality with those cables and housings? I'm running the stock SRAM stuff on mine and the coating on the cables is coming off. It still shifts fine but it looks like crap to me. They run fine on my DA 7800 machine but just wanted to see if it works as well with SRAM.
Thanks,
Chl
Thank you. I haven't ridden it yet. I live in NY and the weather is just starting to turn good but its still very muddy on the roads, so I am riding my beater until the roads dry up. I will cut the steerer once I figure out where it needs to be cut at, as of right now its at its max and I will spend the first month dialing the height.mikeyp123 said:Dudes nice bikes... but seriously, chop down those steerers.
sponger78 said:juanj, I'm only 5ft 3 and 140lbs, and yeah it's a 48cm. This is my 1st road bike, but I have been riding mountain bikes for a while. The only thing I can say is it's light (17lbs), stiff, and fast. As comparing it to my other bikes it's a Cannondale just like my other ones, it's pretty sweet.
Thanks. This model and size is top of my list to test ride.sponger78 said:juanj, I'm only 5ft 3 and 140lbs, and yeah it's a 48cm. This is my 1st road bike, but I have been riding mountain bikes for a while. The only thing I can say is it's light (17lbs), stiff, and fast. As comparing it to my other bikes it's a Cannondale just like my other ones, it's pretty sweet.
