The width is the same, but you do know that the link is not reuseable?smokva said:Is SRAM 10s chain compatible with Campagnolo 10s groupsets? I can't find that fact anywhere and I would really like to use SRAM chain because of its PowerLink.
Hmm....I didn't know that SRAM 10s PowerLinks are not reusable like 8 and 9sp ones. If that is right than Campy chain with some kind of reusable link that will fit sounds better. All I have to do is find a link that will fit.C-40 said:The width is the same, but you do know that the link is not reuseable?
There are two reuseable links that will fit either the Campy UN or SRAM chain. Forster makes a 5.9mm Superlink that will fit and the "Shimano compatible" version of the wipperman connex link, marked 10S1, will also fit properly.
I think you'll find that Campy chains elongate far less than any other brand, whihc makes them a better value overall.
Shimano employee? Sounds like a scientific response.ElDuderino said:sram chains last for about a month...just fyi.
yep. This is what i use... pretty simple !BenR said:The cost of a Campy Veloce chain + Wipperman link is by far the best bang for the buck..
No, they don't.ti-triodes said:Don't 9s ShimaNO chains work with 10s Campy?
Richard said:No, they don't.
I don't have the spec sheet right in front of me, but all 9 speed chains are generally about 6.6mm to 6.8mm wide.ti-triodes said:I believe Leonard Zinn was talking about them in Velonews last year. He said it did work.
