1 - 4 of 4 Posts
my uncle sent me this old track frame he built up in the mid seventies when he use to race for the Trek factory team in Wisconsin, back when it was a one shop deal. I had it powdercoated and clean up cosmetically very nice, but had problems finding a chainring that would fit the vintage campy pista crankset. I measured the bcd, and obviously measured wrong thinking they were 144, and of course, pista engraved on the inside of the crank arm, must be a 144! Buy a 144, its too small, the shop I get it from are puzzled and have never had a case like it. I ask how much to order one? For a true campy 150, 200 dollars for the chainring itself!! I was blown away, so instead of doing the vintage restore, I went modern and purchased the sugino 75 200 set (Im a student, gimme a break). The bike turned out excellent and is a blast to ride. But the chainring, the head mechanic at the shop told me since its such a rare and mint crankset, I could get possibly 5-600 dollars on ebay for it. Just seeing if anyone else here has heard of the 150 track crankset before?
Lizzie will ride free
Sounds like a nice bike. That 150 BCD pista crankset was the Campy standard for the day. (Correction 151) There is currently a bit of a revival in the fixed gear world, so a real pista crankset would be of interest to a bunch of folks. I doubt it is in the $500 range, but you should just check the completed sales on e-bay to get an idea. If it is 1 inch pitch (looks like every other tooth is missing) it's worth more, but it's most likely newer than that if it came on a Trek.
It's 151 BCD, which is what Pista cranks were until the early 70's. NOS Rings are expensive but not more than $50-$60 if you search around. Try Bicycle Classics, or Velostuff. They will be 1/8 as well so keep that in mind. You can find whole cranksets for about $250 for a used set. 1960's Campy road rings were also 151, so it is possible to find the then common 48T rings in 3/32 if you do not want to run a 1/8 drivetrain. The 151 Pista set has to be one of the prettiest cranksets ever. Here's a set I polished on my Cinelli.
http://www.wooljersey.com/gallery/album145/newoly4
1 - 4 of 4 Posts
