twelvepercent said:
Weight weenies shows + 2/3% on the few they tested......your Zondas' come in @ what looks like the older (1730 claimed; weight weenies:1698).....I am wondering if they sent you NOS and claimed '08......IF this is true, maybe they will swap you for '08's.....I'm sure you would be psyched to lose 100gr.!
Good points on the Neutron.....I had heard about clicking problems on the OP's and cracking on the DT rims.....I think these problems have been cleared up. I got my '03 Neutrons for $450 shipped; have put 35,000 mi on them, gotten several pinch flats from potholes and rocks and they are still perfect.......compared to Campy list prices custom is a better value for sure....
What is your preferred custom build on Record hubs to get closer to 1500gr.??
naw, they are def the 08 versions, 24/28mm, alloy hubs, bladed spokes etc etc, i know and love my campy wheels, but it is well known they are heavier than spec. Ventos/Scirroccos are actually >1850g rather than stated ~ 1750.... 100g is not a big deal, but one can build comparable, easier fixed wheels that are also lighter.
Right now i am building Zonda killers... I was gunna get them, but when the price went up + 1.7kg wheels, i figured i could do something repairable, lighter and more aero. Importantly they are not significantly aero and would drop only 100-150g over my current Ventos in the real world. (for a lighter/more aero build, think Nio rims + light hubs, can easily get into the 14XXg range....)
OP rims = 870g
Actual record hubset weight = 349g
Dt comp DS, revo elsewhere = ~ 352g
total = 1571g.
or around 30g less if you go all dt revo/sapim lazer/cx-ray.
now of course there are other options like the interesting 22mm Nio22 rim @ <390g ea actual. Drops more than 90g over the above. My fav thing is to combine the excellent, price competitive and light record rear, with a front hub in a lower count, lighter and just as good quality... think WI, Hope etc... with a Nio 22 one could go as low as 24h in the front and still have more spokes than the Neutron setup. It all depends on what you are actually looking for in a wheelset, outright durability with redundant spokes or lightweight etc...
check out more realistic weights of a limited number of wheels here:
http://www.rouesartisanales.com/article-15988284.html (actual test).
