Has anyone ever had an issue with a Campy ergolever right out of the box?
Tonight i tried to install a left (front derailleur) Campagnolo post 2015 11 Speed Record lever and when I tried to feed the cable up from the bottom through the hole into the end of the ratchet wheel and then through the top of the lever it was VERY rough right out of the gate! Too rough to even use. First time using this brand new lever. No crimps in cable. Seems like lever is bad.
As far as I can tell the ratchet wheel hole that holds the end of the cable doesn't seem to be lined up with the hole in the lever where the cable exits!
Unless I am missing something? Any suggestions? Thanks for the help in advance.
Nik
Nik
