I have a bike set up with Chorus 2003 crankset. I removed the BB two years ago and replaced it with a new one since there was some play. Yesterday, I realized that there is play once again. I rode approx. 11,000Km on the bike and the timeframe is exactly two years since the last (and first) BB change.
I'm confused since it's been only two years since the BB replacement and previously it lasted around 6 years.
I tried to remove the cranks and managed to remove the left hand crank arm using the appropriate tools. When i came to the crankset, the inner thread of the crankset seems to be worn out, since each time I locked the tool tight in order to extract the crankset, the tool would not extract the crankset and instead the tool itself would come out and bring out with it a few of the damaged crank's thread screw metal grooves.
So, now that the crankset outer thread is damaged, is it possible to remove the crankset by hitting it from the opposite direction?
That way I can remove the BB and clean it, maybe making it last longer.
Any suggestions would be appreciated.
