1 - 8 of 8 Posts
Discussion Starter #1
that is sold at Home Depot. Its rechargeble and a charge lasts a long time. The built in pressure gauge is accurate too. I took off the standard head and added a Silca pump head to mine.
Riding towards Delmarva.
Air compressor for my offfice?
Anybody recommend an air compressor for my office?
Electric
small
dependable
SOLID psi gauge.
I like to check my pressure often (multiple bikes) so a solid gauge would be mandatory.
Kant phuckin sphell
So...
Electric
small
dependable
SOLID psi gauge.
You dont like a good floor pump?
NeoRetroGrouch
Since someone else brought it up - why would you want a compressor? I see people with those things at rides and I have my tires pumped before they get the cord unwound. With a pump you give it 2 or 3 pumps and your done. - TF
Discussion Starter #5
They come in handy sometimes.
I have a disk on my TT bike and you have to use a Silca adaptor that barely covers the valve. It won't stay on the stem unless someone hold it on. For me, at least, its a two person effort with a regular pump. With the compressor, I can do it alone. To each his own.
Yeah but, are we talking compressors with a tank?
I have a cheapo Job Mate compressor, 3gal and it cost less than $80cdn. I bought it for filling tubeless tires.
I have not found one of that sort that pumps much more than 90psi, even the ones rated for higher pressures don't seem to hit much more than 100.
Thoughts?
Discussion Starter #7
Mine does not have a tank.
I don't recall how high the guage goes on mine, I stop at 120psi for road tires and 160 for tubular on the TT bike. Seems to be at least as accurate as the gauge on my floor pump when I give them the "pinch" test after filling. Who knows how accurate either really are.? I don't check them with a separate gauge as you lose a lot of pressure just checking on a presta valve.
G
I recently bought a compressor to use in my garage for pumping up tires. After humming and hawwing for weeks over whether I really needed it or if I could make do with a floor pump, I decided to go with a Campbell Hausfeld FP2052. It has a two gallon tank with a max pressure of 135psi.
It is awesome. I paired it with one of the United Bicycle presta inflators from biketoolsetc.com and I love it. Two seconds, I let it pump until it can't pump no mo', and I get a nice 125psi in my 22mm tubulars! I then use an external gauge to dial in the pressure to exactly what I want - which I always did with my floor pump.
I keep about ten new tubulars stretching on rims for the day that I need them. Pumping them up with this is a breeze. With the floor pump I would be huffing by the fifth one! I didn't have one of the big volume floor pumps ( tried one of the big volume two-stage blackburrn ones but it gave out quickly and died!).so I would really have to do a lot of stroking.
I say go for it. I got my C-H off ebay for $48. I have seen them retailed as high as $160.
You won't regret it.
1 - 8 of 8 Posts
