1 - 7 of 7 Posts
I recently built up a Specialized Roubaix with Centaur and a 50/34 compact crank to train for and ride the Death Ride (130 miles w/ 16,000 feet of climbing) and have been using a 12-25 cassette. Having the smaller gears has been great for spinning during endurance climbing rides but the 50-12 has been killing me on the fast group rides with rolling terrain. I've seen the Token 11-27's on eBay and can live with the 27 but they are lightweight and spec'ed to only last 1000 or so miles. Anyone know where I can find an 11-25 or 11-27 that will last?
chamois creme addict
Hybrid
The best plan would be to buy a 12-25 Centaur or Veloce cassette, and then ditch the 16T cog for the 11T cog. Centaur or Veloce because the 16 is a loose cog, on Chorus or Record it is paired with the 17. By my best guess, you would actually need the 11T and the 12T plus the 11-specific lockring (from either 11-23 or 11-21 cassette). The 12T from a 12-25 won't work as well because the outer side is machined to accept the locrking. For Centaur your cassette would then be 25-23 (paired), 21, 19, 17, 15, 14, 13, 12, 11.
Excel sports sells the 11T sprocket for something like $50! If you are really committed to this venture, I can provide the lockring plus 11 and 12 tooth cogs from a used 11-23 (there is very little wear on the 11 and 12 as the cassette was on a training wheel that saw lots of use on the 14-21 sprockets). All you need to do is pay me the shipping cost. You would then need the Centaur or Veloce cassette. PM me if you are interested.
Squirrel Hunter
Mix and Match
Close, but he already has a 12-25 cassette. He needs to buy an 11-23 cassette. Buy an 11-23 Centaur cassette. Then you will get an 11t cog along with a lockring to fit the 11t. You will also get a second position 12t cog. Buying a whole cassette at this level will probably be cheaper than going out to buy one or two cogs and a lockring. Now you can ditch a cog out of your current setup and use the 11, 12, 13... from the new 11-23 cassette. You might find that you want to keep the 16t cog if you use it a lot and skip the 12t cog using just the 11t for those really fast rides. Think about what you use most.
Another option rather than customizing a cassette would be to use the 11-23 for those fast group rides with rolling terrain. When you are going out for an endurance climbing ride put the 12-25 cassette on. Rather than having one all purpose cassette have two cassettes and use the one that fits the ride for the day. I can change a cassette faster than most people can change a tube. I would hate giving up a 16t cog I use a lot for those occassional moments when I might need something on one of the extreme ends of the cassette.
1 - 7 of 7 Posts
