I'm using a Centaur '06 / Veloce '05 combo right now, and it seems to work fine. The chainline and spindle taper and symmetry are the same as far as I know. I did find that if I torqued the non-drive side cup to Campy's torque spec, the spindle had excessive rotating resistance, so I had to back it off significantly and use Loctite. This doesn't have anything to do with the crankset though.
