1 - 4 of 4 Posts
I acquired a road frame with english threading in the bottom bracket.
In doing a little research and asking questions-it seems that the correct bottom bracket to put in that frame is 68 mm x 102mm. I measured the bottom bracket shell and it is indeed 68.
In pulling components off an Italian threaded frame I measured the spindle length at 111 ?mm.
I'd hate to order the wrong BB.......
Is 68 x 102 correct?
I do understand that Italian BB shells are 70mm and maybe thats why the italian spindle has to be the longer length.
Much thanks
not related
Much thanks
spindle length and Italian vs English BB are not related. You use the same cranks regardles of the BB. The spindle length is related to the cranks you use. In the past the lower end Campy groups used a loner spindle that did Chorus/Record. Check what your cranks expect
That's right- record and chorus cranksets use a 102; the others use 111, and in some cases a 115.
1 - 4 of 4 Posts
