These 9-speed Mirage brifters are new to me and I don't know how to spread the calipers for wheel removal. There's a trick here somewhere, please clue me in.
breadrunner said:You may be referring to the Golden Angle best described in the Davinci Code. I just move mine around depending on my ride attitude, usually somewhere between Superman and Mary Poppins.
Friction_Shifter said:I take it the 90 degree head tube/bottom of bars is a starting point for fine tuning fit? Didn't realize that (if that's what it is). Is the bottom of the brake lever there too just by coincidence or is that also about where its supposed to be (does this vary by brake levers or are they all (at least the more recent ones)"similar enough". thanks
ladies and gentlemen--we are now floating in outer spacerocco said:That's a leftover from a previous discussion and another context. It's sort of traditional and that's just the way I do it. Actually having the bottom of the bar between flat (parallel with the ground) to 90 degrees in relationship with the headtube is somewhat traditional and advocated by guys like LeMond and Hinault. The way I'm set up is probabaly about as much as you would want your bars to be tipped up. It works for me and lots of other folks but do what works for you.
Bocephus Jones II said:ladies and gentlemen--we are now floating in outer space
Bocephus Jones II said:didn't the question get answered when alienator posted a pic of the little button you push to release campy brakes?![]()
excellent! seeing a spiritualized ref here just made my day. i'm going to finish breakfast and go on a bike ride with jesus....rocco said:Spiritualized?
now I'm doing heroin with Jason "Spaceman" Pierce and ladies and gentlemen--we are now floating in outer space...
