1 - 5 of 5 Posts
I recently bought a new set of chain rings for my 08 compact centaur cranks. I went to put them on last night to discover that they don't fit properly on the cranks. Completely tightening down the bolts results in warping the ring laterally. I was a bit surprised because the chain rings in question are campagnolo record 50/36 110mm rings. I took the cranks to three shops and they are not warped at all; the rings just don't fit on properly.
Has anyone else out there heard of this? I was told that I need specifically centaur chain rings. Before I send back the rings I'd like to make sure of this is true.
Specific rings
Record/Chorus are different from Centaur/Veloce in many ways, chainrings included.
Note- Campy compact chainrings are not true 110BCD rings. Of the 5 bolts, one is slightly outboard from the others, making Campy "110BCD" different from true 110BCD.
Ostensibly they do this to ensure proper orientation for the shifting gates, though I don't understand why they can't simply use a timing mark as they have for so many years on their 135BCD rings.
BTW- I don't know if this propriety pattern is in all models of compact cranks, nor what year it started, but it's something you have to be aware of when replacing compact chainrings.
Banned forever.....or not
They want to make it impossible for people to install Shimano 110mm rings.
Fast No More.
Specialites TA makes compact rings (the Nerius line) that fit the 110/112 Campy CT pattern (the oddball hole is behind the crankarm, IIRC). Stronglight might make them, too, if you really don't want to buy Campy rings. I remember reading that all Campy CT cranks had the same 110/112 BCD pattern, but that the Fulcrum compact cranks had a standard 110mm BCD all around.
Hope this helps.
1 - 5 of 5 Posts
