How do them look?
  • Beautiful as ever
    Votes: 43 59.7%
  • Ugly as hell
    Votes: 9 12.5%
  • I seriously don't care
    Votes: 16 22.2%
  • I ride shimano (and shouldn't have clicked on this thread)
    Votes: 4 5.6%
1 - 20 of 20 Posts
Twitterpated
But I play one on TV
I'm not an engineer, but I'm not wild about this design. Bearings aren't sealed and how is the BB/axel supposed to stay together under power with just those interlocking teeth. (disclaimer, i haven't read anything, I just shot my mouth off after looking at the pictures.)
Thanks,
Tshirt
P.S. I love Campagnolo
Thanks,
Tshirt
well, i ain't no engineer either, but the bottom bracket cups are missing from that photo, so that is how I assume the bearings are sealed (at least in the photos i have seen of the new campy stuff), but what I don't get is how is it all held together, which i guess is the same thing you are asking too.
my legs hurt
brakes, look horrible, but i dont like any road brakes, they all look like asymmetrical pieces of crap in my opinion, though campy's loom better than shimano with that fugly little lever on the brakes.
he crankset stays together with single bot that goes between the two halves in the middle. better break out the loctite for that bolt, be kind of embarassing to have the crankset fall apart. They will have cups that seal the bearings.
Those small gears look like helicopter gears and i'm beting they will be plenty strong to withstand any amount of torque you can put out...but they rely on the single bolt being well closed, I can imagien the nightmares associated with the bolt being just a little loose, or a smalle rock getting into the teeth, does not seem like the best design, but i'm just a software consultant, whet do I know about engineering bike parts?
Fini les ecrase-"manets"!
I like the brakes, I think they look really nice.
I hate the retreat from regular-ol' square taper cranks (I think I've made my view of this capitalizing on upgrade-itis pretty plain in the past), and like others, lament that you can't get any of this stuff in silver instead of black. If it's not carbon, why can't I get silver? And if I don't want carbon, I'm stuck in the lower ranges (and there are signs that aluminum is just going to get pushed down and down the range).
Of course, when all the dopes jump out there and get the new, incompatible cranks, there should be plenty of top-level square taper Campy stuff on the used market.
Premium Member
I like shiny, too.
Hopefully Campy will continue to offer Record in both black and silver.
I'd have to see them on the bike, but those '07 Record brakes don't look as nice as the current ones to me, even if they look more modern.
Then again, I think the Athena-series single-pivots looked better than 10-speed Record does, so I'll trade a little looks for function if I have to.
I'm not an engineer, either
ultimobici said:
The axle is joined with a single bolt. It is the same method used to join car crankshafts together. If it's strong enough for that I doubt any mortal will manage to pull it apart unless a muppet fitted it!
But per some quick googling, that's something called a "Hirth coupling" and it's used for, among other things, holding together the shafts of jet turbine engines. It's designed to handle huge amounts of torque, with minimal load on the fixing bolt. Pressure between the teeth of the joint carry all the torque load, and the fixing bolt just keeps the teeth together.
Twitterpated
JCavilia said:
...holding together the shafts of jet turbine engines. It's designed to handle huge amounts of torque...
I don't like to brag but about my physical strength but...
Well, I stand corrected, seems like they've actually got a pretty advanced system. Thanks for the info.
Thanks,
Tshirt
"Cypress Gardens" Fl.
Brakes look like "zero gravitys' to me. Different, but kinda nice. Sort of blocky looking. Will I trade them even-up for my polished "Athena" single pivots? Hell no. Those Athenas "sing" on my bike.
Adrenalina Italiana
I like the new design.
It looks as though it will be pretty easy to install and even better you won't have to buy any new tools! Although,I'll probably end up buying the '06 carbon groupo to convert my last bike over to Campagnolo. I'll let it prove it self under racing conditions for a season before I bite.
Not Banned
I agree
brake borrows from zero gravity. pretty nice looking in a modern derillium sort of way.
1 bolt and I think 1000 lbs of torque. will hold far more than ours or Tom Bonnen's legs could ever create. The teeth distribute the load so each indv connection bears very little of the total load. simple, strong most likely very easy to service and maintain. My guess is Campy did tons of R&D before releasing it, instead of jumping on the other bandwagons. I'm sure they are showing up late to the outboard system because they found a superior design. my guess is they'll make boogers out of everything else
1 - 20 of 20 Posts
