In a way the 8 speed is a good thing, OTOH, however...
the 8s is getting to be sadly "old school". On the good side, an 8s wheel is not as flat (spoke angle) as the more recent 9-10s wheels, and for many folks 8 cogs is sufficient.
However your options are not great if you want a modern factory built wheel. They are mostly 9-10s. You can, however, buy a set of fancy new rims and have new wheels built on your old hubs, or you can splurge and find new 8s hubs and have them built into wheels with the rim of your choice. That would rock.
This is from the official Campagnolo website::
8s groups and compatibility:
Can I put 8s sprockets onto a 9s hub?
No, they would damage the freewheel because the shape is different.
Can I make a 9s sprocket set out of an 8s sprocket set, by changing the spacers and adding the ninth cog?
No, because of the difference in thickness between 8s and 9s cogs.
Are the 8s Record steel sprocket sets still available? Yes.
Does the 9s rear derailleur work in the 8s drivetrain? Yes, if the C9 chain is also used.
Can I make a 9s sprocket set out of an 8s sprocket set, by changing the spacers and adding the ninth cog? No, because of the difference in thickness between 8s and 9s cogs.
Can I use the ErgoBrain computer on my 8s bike?
No. The integration is only possible with the ErgoBrain ready Ergopower levers. In addition, the indexing is different.
Can I use the new ultralight 9s/10s hubs with my 8s group?
Yes, but only with a 9s Veloce UD (or Mirage UD) sprocket set and the conversion kit "KIT-03", available from Campagnolo retailers.
Can I use a 9s rear derailleur with my 8s drivetrain? Yes, but it requires the C9 chain.
Does the C9 chain work with the 8s drivetrain? Yes.
Yes. They are available in the following combinations: 12-23, 13-23 and 13-26 (see the spare parts catalogue).
Can I convert my 8s Shamal (or other 8s Fluid-Dynamic wheel) into a 9s by changing the freewheel body?
No, it is too dangerous because of clearance problems between the derailleur cage and the spokes.
Can I use the Nucleon / Neutron wheels, or any other 9s/10s model on my 8s bike?
Yes, but it is necessary to use a 9s Veloce UD (or Mirage UD) sprocket set and the conversion kit "KIT-03", available from Campagnolo ret
mach5 said:
I said rims but meant wheels. Any recommendations on a new wheelset?
