I did it!
ox_rider said:
I am interested in hearing from riders who went from riding exclusively Campy to now riding exclusively SRAM. Which Campy group did you have? Which SRAM group do you have? Are you happy you switched?
Thanks.
Until this January, I have exclusively ridden campy equipped bikes. My most recent campy bike was a mix of 1996 Record levers converted to 9 speed a few years ago, Chorus rear derailleur, chorus front derailleur, C9 chain, veloce 9sp cassette (12-23), chorus dual pivot brakes, and a Truvativ Carbon Rouleur compact (50/38 or 50/36) crank.
In January, I happened upon a ever-so-slightly used, SRAM-Force equipped full carbon Merckx MXM. And that was that.
The campy stuff went to the cyclocross project bike and the old road frame transformed into a new FOX rear shock for the MTB.
Here's what I can tell you about FORCE vs older Campy:
1. the SRAM brifters blow away the older campy in terms of ergonomic comfort.
2. Shifting is quick and precise, though how can you really do better than Campy on that front?
3. FORCE
sounds like poorly adjusted Campy when shifting, but it works well. It's hard to explain, but the
click of FORCE just sounds different.
4. FORCE is very easy to set up if you follow SRAM's excellent, simple instructions.
5. I really miss the front derailleur trim of Campy. I mean a lot. I think this is my only gripe. FORCE gives you only one position in the big ring and two in the small ring. There are cogs in the back that I think I should be able to access when in the big ring without that slight rub of the front deraileur. I may just need to fiddle more with the front shifting, but it might just be what it is. RED supposedly addresses this by giving 2 for the big ring, but only one for the small ring.
6. The drivetrain is a little noisier than well-adjusted Campy.
7. The SRAM chain seems to not hold lube all that long and when it gets "thirsty", it lets you know by becoming more noisy.
8. Brakes are OK, though not as good as you can get. I'm not sure if it's the pads on AL rims, or the mechanical action of the calipers. They stop you, but don't offer as much adjustment as Campy dual pivots do.
9. I
sometimes still reach for and miss the thumb paddle down-shift action of Campy, but the Double-Click action suits my riding, so it's sort of a wash.
10. I waffle on weather or not I would have rather had Chorus or FORCE on this bike and usually come down on the side of Chorus, but not so much that I ever think about spending the money to swap.... But then I put my hands on the FORCE brifters and that thought goes away.
Hope this helps a bit.
