1 - 8 of 8 Posts
yep... dunno which wheel u are talking about. but the answer is yes.
You can use any front wheel you wish, as long as it is 700C on a 700C frame.
For the rear, campy wheels do come in shimano freehub versions if required. There are also other ways of arriving to a solution, but that is the best/easiest.
Depends on the model, but Campy sells several wheels with the option of Shimano specific freehubs. To complicate matters, depending on the year, some are 10 speed specific meaning you can only use a 10 speed Shimano cassette starting with 11 or 12 teeth so you can't use older 8/9 speed cassettes or SRAM cassettes with them. You have to check the tech specs for the particular model and year to sort it out.
1 - 8 of 8 Posts
