It has worn on me. Campy has a stellar record so the design at least works. I don't think for a second that is is superior to a standard build, but it's not inferior either.gizzard said:I know they have justified their G3 spoking from an engineering perspective, but I just can't seem to get used to the aesthetics. Anyone feel the same?
It chouldn't be a problem. The concept of truing and properely tension a wheel is the same. The rim has to be much stiffer in order to insure it is straight in between the clusters.gizzard said:What's it like when trying to true a G3-laced wheel. Logically it would seem quite a challenge especially between the three-spoke clusters. Is this the case?
Ihave yet to have any need to apply spoke wrenches to my Zondasgizzard said:What's it like when trying to true a G3-laced wheel. Logically it would seem quite a challenge especially between the three-spoke clusters. Is this the case?
Ya I've put about 7k miles on my 03 Eurus wheels and have not had to true them. And there are some pretty crappy roads here in Sonoma county...........Room 1201 said:Ihave yet to have any need to apply spoke wrenches to my Zondas![]()
Over 7,000 miles on my 04's and they have never seen a trueing wrench. They have seen plenty of potholes. I use them as my winter and roller wheels since the hubs are so easy to rebuild with standard ball bearings.gizzard said:What's it like when trying to true a G3-laced wheel. Logically it would seem quite a challenge especially between the three-spoke clusters. Is this the case?
Apologies, then I suggest that you buy what looks best. And post it on a blog somewhere.gizzard said:I don’t remember mentioning, or insinuating for that matter, that I have a set of G3-laced wheels. It was simply an observation regarding the aesthetics of the design. I was merely voicing an opinion about Campy’s G3 lacing, which, ostensibly is what blogs are all about i.e. people voicing opinions.
