1 - 3 of 3 Posts
I have an Ultegra 9 speed compact double with an 11-25 cassette. I'd like some bigger cogs in the back and have an old 8 speed cassette, 11-28. Can I replace the 9 speed cassette with the 8 speed? Thanks.
Cycling induced anoesis
As long as the 11-28 is compatible, yes. Keep in mind that the 8 spd cassette is about 5mm's narrower than the 9 spd, so you'll have to compensate for that.
Also, because you're running 9 spd shifters with an 8 spd cassette, you'll have to use alternate cable routing:
http://sheldonbrown.com/derailer-adjustment.html#alternate
... and you may have to add a couple of links to your chain. RD limit screws and b-tension will likely have to be tweaked as well.
1 - 3 of 3 Posts
