1 - 9 of 9 Posts
I bought Schrader tubes accidentally and I obviously needed Presta's. So can I bore out my rims to except Schrader and what will happen if I put Presta back in, will tube blow? They don't seem to make an adapter to let a Presta fit a Schrader.
So whats the skinny on this? Thanks anyone
It seems extreme to me to drill a rim because you bought $10 of the wrong tubes. Narrow rims almost exclusively accept presta. I'd be concerned about weakening the rim too much if it's a narrow road rim. Just go to the bike shop or Amazon and buy the correct tubes.
a real member's member
1. use schrader valves in schrader rims only.
2. use presta valves in presta rims or in schrader rims with an adapter.
3. return unused merchandise to the seller for a refund or replacement.
4. boring a larger valve hole in a presta rim to use a schrader valve should only be done in an emergency or apocalyptic conditions.
  • Like
Reactions: chriscc63
presta valve adapters for schrader rims:
As others have said, don't drill out your rims. Return the tubes, or sell them or give them away, and get the right ones. Presta valves are better for high-pressure low-volume tires as on a road bike; that's what they were invented for. They make proper inflation easier and more reliable.
All good and Awesome advice. I was unaware of these adapters.
Ok, so I shouldn't drill them wider. I don't see that this will make the rim that much weaker, but I got ya and won't do it.
these stupid tubes are a hard to find 37-622. got them clearance online "probike" and will cost me to mail them. I think the size translates to 28x1-3/8" or 700x35
Thank you both.
Just to let you know, any tube 700cx32/35 will work for your tires. Hell, even a 700cx25 tube would work. The rubber for bike tubes expands quite a bit. In a pinch, I've even used 700x28/32 tubes in my 26"x2.25" mountain bike tires/wheels. You don't need exactly the right tube size, I just wouldn't recommend going OVER the needed size as then you have excess material that could get pinched between rim and tire more easily.
This is the most important lesson you will have learned from this thread, OP. You were under the misapprehension that you have to match the size precisely. Now that you know about this stretch thing, you will realize that suitable tubes for your tires are not at all hard to find. In fact, pretty much every outlet, local or online, that sells bike stuff will have them in stock.
Discussion Starter · #9 ·
Thanks Tex, and JC, and all others. I recently learned of the "tube fit theory" and can now get a "good enough" sized tube. This has been an enlightening thread:thumbsup:
1 - 9 of 9 Posts
