I run Michelin sprints (a very wide 30) on OPs at ~60 psi and have never pinch flatted, but I seldom use them on pavement where there would be sharp corners to hit. I weigh 190-200 and pinch flat 105-110 psi Axial Pros and Open Pros way too often.jrm said:or is it a pinch flat disaster in the making? The rim would be used on a SS CX bike. So ti going to take alot of load.
atpjunkie said:I've run Geax 38's on O/P's never had an issue. Pinch flatting isn't what you are worried about I'll assume it's the tire blowing off the rim. I'm 230 and rarely pinch road tires to proper psi, if I go low psi cx it does, have to run 15-25 psi higher than most. It's why I switched to tubies for race tires.
have friends that do. I run 34 Tufo Tubies and 30 Tufo Tub/Clinchers so pinch flat isn't an issue. On training Wheels I run clinchers with standard tubes. The last race of last season (2002-2003) was my one shot at victory. I had lead the entire race, my training partner and main competition (though I spot him 15 years and about 80 lbs, I'm old and big) bridged up to me and we had well over a minute on the field. I'm a stronger technical rider than he so I had to make my attack in the technical section if I stood a chance of beating him. Anyhow I pinch flatted my front tire making the pass and rode the entire last 3 quarters of a lap with a flat front. I went from no worse than second (and the one chance I had to beat this kid) to 4th. Grrrrr, needless to say that was my last race on clinchers.jnichols959 said:interesting product (spinskins). hadn't heard of them before. have you been using the race or duro model? the race model is pretty spendy...
yes, not only spare wheel but spare bike. (it is why I'm in favor of 2 cheap bikes vs 1 expensive). I actually have 2, but course design made the pit only accessible at the start /finish (bad). They could have altered the pit placement by about 50 yards and had it accessible from 3 places (good) so I flatted about 25 % into the last lap. It made my next trip to the pit area after I was done. So spare wheels are good but you will still lose time changing wheel and in a 45 minute cx LT sufferfest it's all it takes to ruin your race. There rally is no time for comebacks. you may battle back a few spots but that's about it.jnichols959 said:that's gotta hurt... i'm just getting started with the cross stuff and plan to try racing (i dig road racing). i'm more than convinced of the merits of tubs for races. i imagine that a flat in a cross race will cost you lots of positions unless you have a complete spare waiting for you right?
I found that this worked well.jnichols959 said:speaking of pinch flats, have any of you folks had success with using latex tubes where a normal rubber tube would normally pinch flat? i've heard it can help and given the tendency of my road wheels to pinch flat at anything below 110 psi (I'm 175), i'm a bit weary of trail riding on my upcoming cross bike with lower pressure, higher volume cross clinchers. i know tubs are an option but for the initial build, they're not in my budget.
