Cane Creek eeSilk Review
The parallelogram design maintains saddle tilt through the post's 20 millimeters of travel.​
What is it
Cane Creek's eeSilk seatpost brings 20 millimeters of tunable, vertical cushion to road or gravel bikes. At 295 grams it is comparable in weight to traditional rigid performance seatposts while offering cushioned compliance that aims to improve control on rough surfaces and reduce fatigue on long rides. The eeSilk Post comes only in 27.2mm diameter, but Cane Creek offers a wide variety of seatpost shims to accommodate virtually any round seat tube larger than 27.2mm up to 31.8mm. The Cane Creek eeSilk is also Di2 battery compatible.
httpv://www.youtube.com/watch?v=nlWcGAx_h1o
Pros
  • Takes edge off rough roads in subtle, almost invisible way
  • Increased comfort without huge weight penalty
  • Top notch build quality and hardware
Cons
  • Expensive at nearly $300
RoadBikeReview's Take
Who doesn't want a more comfortable ride? Cane Creek's new eeSilk suspension seatpost offers 20 millimeters of vertical cushion, aiding in comfort over tarmac, dirt, and gravel roads.
Weighing only 295 grams, that's pretty light for any seatpost, let alone a suspension seatpost. To lend context, a Thomson Elite in 330mm x 27.2mm weighs 241 grams. The eeSilk is 350mm x 27.2mm. Less than 50 grams is a small weight penalty to pay for the comfort delivered.
Included with the post are soft and firm elastomers (in addition to the medium already installed) and a small tool used when making an elastomer change.​
The stiffness of the post can be tuned via different elastomer inserts. Those elastomers are available in extra soft, soft, medium, firm, and extra firm. The post arrives with the medium installed and it is recommended for riders weighing between 150 and 210 pounds. Also included are the soft and firm elastomers. Others are available aftermarket.
Anyone with a history using elastomer suspension may take pause at the material's in use here. In below freezing temperatures, it's true that the bumpers can harden. Cane Creek's engineers were helpful here, mentioning that depending on your weight, terrain, and personal preference you may prefer a firmer or a more active setup. I rode with the stock medium elastomer fitted and it worked nicely for my 150-pound weight. The post never felt like it was bobbing on smooth surfaces and it certainly took the edge off of rougher roads, noticeably reducing vibrations transmitted to the rider. It's a subtle difference with big ramifications. The longer the ride, the more benefit you'll see. The parallelogram design maintains a consistent saddle tilt but there's no getting around the small change in seat height.
The lower rear pivot can be taken apart in order to change out the elastomer.​
As mentioned above, the eeSilk post is offered in a 350mm length in a 27.2mm diameter and that's the only size available. But with $9 accessory adapters, it can be fitted to seat tubes up to 31.8mm. Likewise, the only setback option is 8 millimeters, a nice middle ground that should work for a large portion of the cycling population. The post is Di2 compatible and carries a 330-pound weight limit.
While the post is a bit pricey at nearly $300, the aluminum construction is top notch and the hardware is titanium. Ultimately, three Benjamins may be a great way to make the bike you already own more comfortable than ever, no matter where you ride.
The Cane Creek eeSilk suspension seatpost provides extra comfort without ruining the look of a bike or adding a lot of weight.​
Rating: 4.5 out of 5
Price: $289
More Info: www.canecreek.com
