1 - 6 of 6 Posts
I just picked up a new bike and have a question regarding the expander assembly headset thingy.
According to Cannondale, the expander assembly must reach the bottom stem bolt. However, I just got this frame and I don't want to cut the steerer tube until I've gotten a few rides in and dialed in the handlebar height. Is it ok to ride it around (not too hard) if the expander assembly is only reaching the top stem bolt? I understand the reason the expander must reach the bottom stem bolt is so that it provides some support to the steerer tube when tightening the stem.
Forever a Student
No.
Don't be stupid and crush your steerer tube. Do you feel like buying a new fork for several hundred dollars?
If you insist on riding around with spacers above your stem, you have to also insist on purchasing and using a proper compression plug that's long and sturdy enough to reach the bottom stem bolt.
That is how professional shops do it.
Maybe I'm just thick but the expander I have can be loosened and moved up or down the steerer tube. So even if I had a bunch of tube above my stem, I could move the expander down the tube so that it was right where the stem clamps the tube. Does yours not work like that?
1 - 6 of 6 Posts
