Axa Nano 40 Steady Light Kit
Cantitoe Road is proud to offer affordable dynamo-powered light kits so that every commuting cyclist can light the way under human power. The Axa Nano 40 is offered in side-mount and hub dynamo versions.
1.) Dependable: Never worry about a battery running down. The dynamo- powered Sprint is always available.
2.) Green: No batteries for the land-fill. Ever.
3.) Self-Sufficient: Make your own juice. Why use a battery to power the light when you can do it yourself?
Side-runner dynamo kit:
  • Axa Nano 40 lux headlamp w/ "Steady" feature keeps light on for up to 4 min when stopped.
  • Riff Steady dynamo powered tail light
  • All necessary wiring and mounting brackets
  • HR Traction Control Dynamo
Side-runner dynamo kit SRP: $159.95
Hub-dynamo kit:
  • Note: hub dynamo is not included in this kit.
Hub-dynamo kit SRP: $119.95
Axa Sprint Steady Light Kit
Cantitoe Road is proud to offer affordable dynamo-powered light kits so that every commuting cyclist can light the way under human power. The Axa Sprint 10 is offered in side-mount and hub dynamo versions.
3.) Self-Sufficient: Why use a battery when you can do it yourself? Make your own juice.
  • Axa Sprint 10 lux headlamp "Steady" feature keeps light on for up to 4 min when stopped.
  • Riff dynamo powered tail light /w "Steady" feature
Side-runner dynamo kit SRP: $99.95
Hub-dynamo kit:
  • Axa Sprint 10 lux headlamp w/ "Steady" feature keeps light on for up to 4 min when stopped.
Hub-dynamo kit SRP: $59.95
To order: https://www.cantitoeroad.com/lights/dynamo-light-kits
