1 - 12 of 12 Posts
Witty custom user title
Looking for some input from those who have a lot of experience with carbon clinchers. So I got an inexpensive set from a buddy of mine to toss on the crit bike. Wasn't looking to break the bank for boutique wheels, and these for the bill for me just fine.
Anyway, I am noticing a rattling noise when the wheel has any lateral pressure on it. As in, when in a turn, when I'm out of the saddle, etc. Does this sound familiar to anyone? The best way I can describe it, is it literally sounds like something rattling around inside of the wheel. That said, they're perfectly quiet when just rolling straight, and all my spoke nipples appear to be where they should be. As far as I can tell, it's primarily coming from the front wheel.
Is something loose maybe? Spokes need tightening? Anything else I should ask my mechanic to look for?
I've had more expensive carbon wheels in the past and don't recall ever hearing a noise like this.
Thanks all, but wouldn't you assume that if it were the valve stem that it would do it when just riding along in a straight line? This noise only occurs when lateral force is applied such as in a turn or when flexing the wheels while out of the saddle, etc. Guess I'll try it either way, but I thought maybe the wheels themselves had something going on...
I wouldn't assume that at all
I've experienced intermittent valve stem rattling that only occurs under certain conditions - although I'm old fashioned and still use the retainer nuts on them, and they occasionally work loose and rattle - I've taken to putting a small O-ring between the nut and rim to help secure them and prevent the rattles.
The electrical tape should work as well.
A wheelist
What have you got invested to try? 60 seconds?
But do what I did for mine - get red tape, cut a square piece and put it on on the diamond. Fan-see. Now you can find the valve faster too.
1 - 12 of 12 Posts
