1 - 7 of 7 Posts
I just purchased a 1986 Torelli in great condition. It has all campy components, and I am looking to do some gear work on it. The current cassette is a 6 speed 13-21. Living in Colorado there are lots of hills, and the 21 is not big enough for me. The question is can I go to a 7 or higher speed cassette without changing other components, or do I just need to stay with the 6 speed and find different sprockets? Thanks for your help in advance
Every little counts...
Chances are high that it is not a cassette, but a freewheel on the back. Not so easy. You should be able to find 7 speed freewheels (you'll need a slightly narrower chain) with as big as a 24 (I may be mistaken, this goes waaay back) in the required thread.
I've also seen (this is fun) that you can friction shift a 10 speed rear cassette if you have the touch.
duh...
can't remember, but were 7-spd chains narrower than 6? the torelli is likely spaced 126, but also steel... so I guess he could squeeze a 130-spaced 10-spd wheel in there. but would also need new chain and perhaps ders (pulleys), and could be opening up more issues
I would like to stay as simple as possible. If it is just a change of the Freewheel (I think you are right spunout) and the chain, that is doable, but more than that I will just stay with the 6 speed
Banned forever.....or not
Six and seven speed freewheels are the same width. The seven is just narrower. A seven speed chain is required. You may be able to find a freewheel with a 26 or a 28.
Seven speed freewheels are much easier to find than six speed.
Harris Cyclery sells 6- and 7-speed freewheels with a 34. don't know if your derailleur will handle the big plate, or wrap the extra chain, but it might be worth a try to get you a bailout gear.
http://sheldonbrown.com/harris/freewheels.html
1 - 7 of 7 Posts
