1 - 6 of 6 Posts
Hi there roadies,
I'm planning to buy the new Zero Gravity OG 04 brakes for my bike. I can't seem to find anyone who has experience with this model or the former Cat Claw titanium 1 Brakes.
CAn anyone tell me if they brake as well as they claim? They claim better performance than Campy and the old Dura Ace brakes.
Thanx for helping out,
Greetings,
Michiel
Le Rouleur
I can say based on experience that yes they are light , better braking no different , the major issue is the return spring replaced twice spring is weak and some of the hardware will start to rust after a few wet rides or cleaning . This is based on the Cat brakes , so I do not know if these issues have been corrected on the Zero gravity models . I have heard the same things from some other users . Other then those issues they are super light but that comes at a cost . Worth it for a climbing bike I guess .
Cheers
Cheers
Thanx for answering; is the service ok for replacement parts? Did the spring not return the caliper or did it break? I live in europe, so breaking would be a mayor issue. Zero Gravity says they redesigned the spring for balanced arm movement, if that was the problem they seem to have solved it. But as you say, they are light and that's what counts. It's important for me, that the breakingperformance is ok.
Thanx again, Greetings :)
Le Rouleur
They are pretty good and quick at first they would not admit the return spring was badly designed, but the replacements where obviously made from a heavy gauge so to date it seems to have solved the problem so I would assume the zero gravity have the new springs. Breaking is fine as long as you are not a heavy rider the only real benefit of these breaks is that 2 calipers are the weight of 1 dura ace caliper on pure breaking performance they still do not out-perform a Record dual pivot . So in other words expect to go uphill quicker but downhill slower .Hope this helps.
Cheers
P.S as a safe guard if you buy these brakes order a spare return spring
Max-Q said:
Check out this thread: http://weightweenies.starbike.com/phpBB2/viewtopic.php?t=1188
and this one: http://weightweenies.starbike.com/phpBB2/viewtopic.php?t=1031
One thing I can say the company seems to have excellent customer service and they seem to stand behind their product. They even sent a pair of the new brakes to a guy for an evaluation.
Thanx guys for the information. I saw that on weight-weenies a discussion has been going on about these brakes and the manufacturer is involved. I read those threads and make my mind up.
Greetings.
1 - 6 of 6 Posts
