Supposedly you're suppose to use ceramic specific green brake pads by Kool Stop.
Ceramic surfaces are brittle and crack easily. But aside from that they can be durable. However one must understand that ceramics are insulators, both electrical and thermal, so the braking energy converted to heat in the brake pad cannot transfer to the aluminum rim where it can be dissipated. This is the reason for rapid pad wear and reduced brake effect, but ceramic only makes the pad operate at higher temperature, so it will limit braking when the pad material breaks down or melt, or at least closer to melting than if it were running against aluminum, that is for standard pads, the ceramic intended pads supposedly won't do that. The main benefit was intended to be for wet braking where you can stop about 50% faster from reports I've read; its resistance to wear is probably also a goal for wet conditions that circulate much grit. And if they chip they will shutter under braking.
Personally I don't see any real advantage, and they get real ugly as they wear. But make sure you have the right pads.
