1 - 20 of 25 Posts
I'm awaiting the delivery of my new 2009 Supersix, and I was thinking I'd like to install a chain catcher just as a precautionary measure to prevent the chain from being dropped. I'll be running the bike with a compact setup, either 50/34 or 50/36. Has anyone sucessfully mounted a chain catcher on a Super? I've seen the ones that clamp around the seat tube, but I dunno if anyone makes one that would be big enough or not?
Thanks!
Andrew
I think that you should def get the chain catcher if they make one to fit the size of the super six. I have a 07 caad9 with a dura-ace front derailleur and compact 50-34 cranks and have had a problem with the chain coming off when down shifting.
I have to be careful and really baby it which would not be a good thing if I were racing. I have been lucky in that it has not damaged the frame or finish yet. So I would like to get myself one to asap.
I can only imagine what would happen if the frame was made of carbon could possibly ruin a very expensive frame!
So my question is why don't bike company's sell there high end bikes already equipped with a device like a chain catcher stock from the factory?
I mean they don't cost that much and could save someone from the heart attack they will have when there 3 to 4 thousand dollar frame is turned into fishing tackle!
I had a 08 SuperSix and crashed it 3 weeks ago. Ouch!
However, I have a new 09 Supersix Hi-mod on order. Should get it in early April.
Anyway, One of my riding buddies just bought a BMC and the shop installed a black tie wrap on the downtube right where the small chainring comes close to the tube. It was a pretty thick tie wrap with a big "head". That head was positioned such that if the chain dropped it would hit the wrap and hopefully bounce back on or help protect the finish.
I will try to do this when I get my frame back and built up. Try it.
Another option I have seen on another forum, it was a piece of metal attached to the front derailleur screw. It extended down and had a bend to it. It was positioned just inside of the small chain ring. This appears to be a stronger and better design but would take some effort.
Can we post a link to another forum? If so, I will post it!
ScubaD
I own an '08 SuperSix 1 with a compact DuraAce crank. In over 10,000 miles of riding, I've not had any problems with dropping a chain. The SS came with a metal sleeve over the chain stay to prevent damage to the carbon tube.
I dropped the chain a couple of times on 08 s6 2. The chain peeled the metal guard halfway and scratched the frame abit. I would highly suggest putting a chain catcher if it can be done.
I have a "dog fang" device (I think it's by Third Eye) on my Supersix. I think it's the only one that fits, as the lug on the bottom bracket is too thick for most of the chain catchers. The Third Eye has a metal band that adjusts and tightens with a screw.
Unfortunately, it isn't fool-proof. My son accidently pushed my bike down in the garage, and the chain was caught below the tooth. I think that the problem lies in the inability to get the band tight enough to prevent the tooth from rotating.
If you could machine a metal arm to come off of the front derailleur as I've seen the pros use, you'd be better off. I'd get one of these if they made one big enough
Ngear
Nick at Ngear made one for my '08 Super Six, which is in the process of being built up. I will find out soon if it will work. FWIW, Nick made a custom Jumpstop for my Cannondale Synapse, and it has worked like a charm. He's a great guy, and will work with you until everything works as promised.
Nick did the same for me - in addition to my Supersix, he made one for my wife's Synapse. The only issue with hers was front derailleur clearance. She has a triple, and the bottom of the FD struck the Jump Stop flange. I bent the flange down just enough to clear.
Eugkim -- What year is your Super Six? I will be fitting the Jumpstop on my '08 SS next week and I would like to know if you encountered any fitting problems. Thanks.
Thanks for the info. I just checked the measurements I sent to Nick. My educated guess -- based on the placement of the Jumpstop on my Synapse SL 1 -- was that the Jumpstop on my Super would sit on the wider lug area rather than on the narrower part of the seat tube. BTW, my crank is a compact, if that makes a difference. The crank on my Synapse is also a compact. I guess I will find out if the clamp Nick made for me is too big next week.
I am interested by that, my system six has a SI crankset, can I install that without a probelm????
That should not be a problem. I have that crankset on my Synapse. Contact Nick at Ngear. He will come up with a chain catcher that will work for you.
lint picker
I use a standard dog fang. Ziptie wrapped around the entire dogfang and thru the holes to hold it in place.
I wrote an email to chain catcher Guy, a week ago and no answer, the business is still open??
Yes. I spoke to Nick not too long ago. He had an accident where he injured both of his hands. He is recovering from his injuries and is just getting back to being able to make custom bands for the Jumpstop. Try giving him a call.
1 - 20 of 25 Posts
