I have a Shimano Ultegra di2 set up, 53/39 in the front with a 28-11 in the rear. Chain is tight and not worn, and derailleurs are adjusted correctly.
I am having an issue with my chain coming off to the outside of the large ring when I am lower in the rear cog, anything in the 13,12,11. It has happened twice on a steep and fast downhill with a couple bumps under moderate power, and once when I was sprinting in the 53/12 under high power(I was sprinting so as much as I could put out anyway). Before this happened everything worked fine, and shifted normally. I have adjusted the front derailleur so that it is almost rubbing on the chain on the outside of the big ring to act as a chain catcher or sorts, but is there another reason that I should look towards to fix this?
Thanks for the help!
