The life of chains
xxl said:
Some around here claim 3,500mi. on one, others are done after a third of that.
Measuring for elongation is how you decide if you need a new chain, and all it takes is a ruler. For reference, my current Campy U10 chain has 8500 miles on it and is nearing the end of it's life. YMMV
Ways to make chains last a long time:
1. Keep the chain clean and well-lubed. It's the gunk on the chain that acts as a grinding compound and destroys the chain. I use ProLink, with the standard procedure, every 300-350 miles. This also means a quick re-lube if you get caught in the rain. IME, wax lubes do not meet this requirement.
2. Spin a high cadence. Those who stomp stress the chain far more.
3. Ride in the big ring when you have a choice. Keeping the chain on the larger cogs greatly reduces stress and there is less chain angle in the 53/18 than in the 39/13.
4. Ride in non-dusty regions. The grinding paste that forms on the chain is a combination of lube and dirt. If your local climate is dusty, this problem will be far worse and your chain will wear that much faster.
5. Buy good quality. IME an SRAM chain lasts about 60% as long as Campy, and others have reported Shimano DA lasting less than half as long. Cassette cogs and chain wheels wear at different rates too, and this influences chain wear.
6. New chain = new cassette cogs if the new chain skips when you pedal hard. Many will argue for frequent chain replacement to save their cogs, but the cogs still wear, even with a new chain. The partially worn cogs will cause faster chain wear.
