1 - 3 of 3 Posts
Hi All,
I'm hoping to build up a Pompino 120mm rear end (I can no longer get the 135mm rear end version in an XL anywhere and I already have wheels for that! Bugga).
I need to know the chain line so that I can sort out a crank set. I was hoping that I would be able to run a MTB crank. I have a set so square taper Hollowtech Deores that will do nicely. And this will gove me a lot of chain ring options.
I just need to know the chain line number for a 120mm rear hub, so that I can work out the right BB axle length.
Cheers all
blame me for missed rides
when mounted on 110 or 113mm spindle bb the chainline of that deore is 47.5 to 50mm (middle) with inner at ~42.5mm. the chainline of a 120mm track hub is 42mm. so your best bet is a 103mm BB and use the middle ring.
1 - 3 of 3 Posts
