measuring accurately???
Just how are you taking this measurement? Although it;s certainly possible to have very little elongation after 6000 miles, it's not possible to have none.
I have a campy 10 chain with about 6000 miles on it that has so little elongation that the only way to accurately measure it is by comparing to a brand new chain, carefully stretched out and compared over 4 feet. Over this length I get about 1/16 inch or only 1/64 of an inch per foot.
First, clean the chain. Lay the chain on a bench, on its side and pull it tight. Place an accurate 12” scale on the edge of a pin. I use a precision machinist's scale. The pin at the opposite end will be totally covered when the chain is new. As the chain wears, this pins will begin to “peak out” from under the scale. Change the chain before ½ of this pin is exposed. The maximum allowable wear is 1/16” (.063 inch) per foot. One half of a pin is slightly more (.070 inch).
This measurement can also be done on the bike, holding the scale along the lower section of chain, but it’s a bit tougher to do.
