It may be a small difference but I can feel the difference, just like raising or lowering the saddle an equivalent amount.2.5 mm is a tiny change in crank length. Its like a 1.5% change. The sole thickness on different shoes probably differs by a lot more than that. I think its all in your head.
2.5mm in the world of bike fit is not insignificant. Try raising or lowering your saddle 2.5mm and tell me that won't make a difference in how you feel.2.5 mm is a tiny change in crank length. Its like a 1.5% change. The sole thickness on different shoes probably differs by a lot more than that. I think its all in your head.
Your book is wrong. So tell me, is moving your saddle up or down 2.5mm insignificant? I know I can feel the difference here.1.5% is insignificant in my book.
Statisticians draw it at 5%Your book is wrong. So tell me, is moving your saddle up or down 2.5mm insignificant? I know I can feel the differnece here.
Certainly this always boils down to what effort can be exuded within rider-physiology in an A/B situation.Statisticians draw it at 5%
An inch is 2.54 cm. 10% of 2.54 cm is .254 cm, or 2.54 mm, Right? So we're talking 1/10 of an inch. I think that's right. Get a tape measure and measure out 1/10 of an inch. Mark that distance on a piece of paper. It's tiny. It would difficult to even raise your seat post that little with any accuracy. Why don't stems come in finer increments than one cm if 2.5 mm is such a significant distance?
I know you consider yourself the god of bike fitting, but look at the paper again and tell me you'd really be able to tell a 1/10" difference in your crank length, or seat post length. I sure couldn't.
Well good for you. Seeing as how you think you know what's in my head you're obviously pyschic, how about passing on next week's lottery numbers. My body is telling me it's made a difference and that's what matters to me. What percentage of your height is a 2.5 mm seat change, but a lot of people regularly adjust their seats by this amount.2.5 mm is a tiny change in crank length. Its like a 1.5% change. The sole thickness on different shoes probably differs by a lot more than that. I think its all in your head.
First off, in the world of bike fit, 1 inch is HUGE. 1/10 of an inch is significant.Statisticians draw it at 5%
Try riding without all of those and you will need to adjust your saddle.Thickness of chamois, shoe soles, gloves, etc. 1/10" is pretty small.
I can’t feel a 2mm change but my right knee sure can. I get wicked knee pain if it’s different. It was a real struggle on the MTB initially. I could get it dialed in but the damn seatpost would slip. I’d know what happened because my knee would tell me. A combination of marking the seatpost and lots of Ultra Hold hairspray fixed it permanently.Your book is wrong. So tell me, is moving your saddle up or down 2.5mm insignificant? I know I can feel the difference here.
I think for most people the small mm changes are really in saddle height. I don’t wear gloves. I wear the same shoe all the time and none of my chamois are made from wood. That said, I have had bibs with a chamois I couldn’t adjust to and they have been relegated... I have expensive shorts and cheap shorts that made the cut list because they feel right. Cheaps are for trainer and short targeted training. Assos for long rides. They all compress to about the same.Thickness of chamois, shoe soles, gloves, etc. 1/10" is pretty small.
Oh thank you. More golden nuggets from the God of Bike Fit. I'll adjust my saddle height 0.1" when I wear different shorts.Try riding without all of those and you will need to adjust your saddle.
I'm not defensive, you were offensive. I originally posted to describe my experience and what I felt, because I had also heard numerous stories of "yes you can feel a 2.5mm difference, no you will not feel a 2.5mm difference". My knees aren't getting sore anymore, so it's definitely made a difference for me. I take offence to you playing amateur psychologist and telling me you suspect it's all in my head. For me it's real, not imagined.Oh thank you. More golden nuggets from the God of Bike Fit. I'll adjust my saddle height 0.1" when I wear different shorts.
And to the OP, I mean no disrespect. If changing your crank length a tiny bit has helped you -- good for you. No reason to be defensive. I've been riding bikes for a lot of years. I have 5 road bikes. I've been down the rabbit hole on supposed improvements and never felt much difference. But maybe you do and that's OK. If it works for you -- real or imagined, that's all that counts.
Where do you come up with this? Do you really think there is a 0.1" difference between the chamois thickness any of your bike shorts? That is compressed under your butt.Oh thank you. More golden nuggets from the God of Bike Fit. I'll adjust my saddle height 0.1" when I wear different shorts.
