1 - 5 of 5 Posts
Discussion Starter #1
I'm considering changing out my chainrings for FSA ones. I wanted a 53. I know it wont make much of a differance but still. Is there anything that I should watch out for? Anything to consider? Will the shifting be any different? My DA group is the 7800 series. Thanks for any input you can give.
Carlos
Squirrel Hunter
Train More
los318 said:
...I wanted a 53. I know it wont make much of a differance but still.
Don't bother, it wont make any difference. A couple of summers ago my son and I were the same height and closely matched sprint wise. He rides a 52t for junior gearing and I ride a 53 because it was stock. We would swap bikes from time to time mid ride when training and I could never tell a difference in losing a tooth when riding the 52t. Don't waste your money and time it the extra tooth will not make a difference.
52
Most D-A's are 53, that's been the standard for many years. I'd rather have a 52, it would give me closer ratio spacing and let me stay on the big ring more. But there is very little difference, certainly not enough to justify a change. If I ever wear out one of my 53's I'll replace it with a 52 or 51.
Al
rebounder
keep your drivetrain together. swichting out rings and such all the time will eventually lead to poor performance
And to throw some more confusion into the pot ... :D
I started last year with a newly fitted 39/53 (Ultegra). Despite what folk say, I felt that the 53 was a tadger too much for my aged legs, so took the 52T I had on my 'old' triple and fitted that.
Shifting quality was unchanged, I subsequently fitted a 13 - 25 cassette and all was well for much of last year.
I then fitted a 38T inner (Salsa) and a 50T (TA) outer, keeping the same cassette. This shifted just as well as all the other combos - using the same Shimano Ultegra double front shifter - and I find the combo, now with a 13 - 26 on the rear, to suit my riding needs wherever I end up in my 'local patch'. If I feel an urge to go ride anywhere flat - tricky around DC, it's decidedly 'lumpy' - I have a 12-23 somewhere, which offers closer ratios though the 12 seldom gets dirty.
Of course, what has to be considered is that I'm in my mid-50s, struggling around after 30 years of not riding, or even particularly living decently. Screamin' fit 20-somethings with 4% body fat may approach this differently ;)
Regards
Dereck
For my next trick - 34/50!
1 - 5 of 5 Posts
