Park Tool's New Hydraulic Brake Bleed Kit
Park Tool recently announced a new premium Universal Disc Brake Bleed Kit, BKD-1 (for DOT fluid), and BKM-1 (for Mineral Oil). These kits are designed for both home and commercial use and include everything you need to bleed the most common disc brake systems on the market. The new bleed kits have bulked up designed and built the rigors of daily commercial use. Like most bleed kits it arrives with two syringes, hoses with shut off clips, multi-size bleed blocks bleed funnel. The coolest feature is a unique attachable syringe mount that allows the free movement of the mechanic and minimizing oil spillage.
BKD-1 Hydraulic Brake Bleed Kit BKD-1
  • Designed and built for home use and the rigors of daily commercial use
  • Includes two syringes, hoses with shut off clips, multi-size bleed blocks bleed funnel and a unique attachable syringe mount
  • Housed in a rugged reusable case
  • Machined stainless steel and 7075 aluminum fittings to service SRAM®, Hayes®, Formula®, Hope® and other brands of DOT fluid-based hydraulic brake systems
  • MSRP $117.95
BKD-1 Hydraulic Brake Bleed Kit - DOT
The BKD-1 Brake Bleed Kit will bleed most models of DOT fluid-based hydraulic brakes. Hydraulic systems need bleeding to remove any air bubbles and to inject new, clean fluid.
Check out the BKD-1 in action
httpv://youtu.be/Rt7tI3l72CU
BKM-1 Hydraulic Brake Bleed Kit - Mineral
The BKM-1 Brake Bleed Kit will bleed most models of mineral oil-based hydraulic brakes. Hydraulic systems need bleeding to remove any air bubbles and to inject new, clean fluid.
BKD-1 Hydraulic Brake Bleed Kit Features include:
  • Designed and built for home use and for the rigors of daily commercial use
  • Includes two syringes, hoses with shut off clips, multi-size bleed blocks, bleed funnel and a unique attachable syringe mount
  • Machined 7075 aluminum fittings to service Shimano®, FSA®, Magura®, Clarks®, Promax®, Tektro®, TRP® and other brands of mineral oil-based hydraulic brake systems
  • Replacement parts available
  • Brake fluid not included
  • MSRP $139.99
Check out the BKM-1 in action
httpv://youtu.be/fXvc2lPjDvA
Both sets are available now at ParkTool.com
