How is the frame holding up? I bought the same one (in glossy black) and am anxiously awaiting a shipping notification.So I finished the build, was a shame I had to use the old chainset its got millage marks but tough nuts the mrs already has a gun to my head.
The only genuine issue I have is that the seat post is undersized but from reading around this can be a common thing for carbon posts and especially aero shaped posts, even with an excessively tightened wedge.
On the first ride out I had to stop twice and lift it back out. I settled on fixing it buy adding a double height and double layer of black PVC insulation tape around the clamp area for the wedge to bite into and also a single height single layer around the bottom which only just slid in to prevent back and forward movement inside the frame pivoting from the clamp point so it cant wiggle its-self down.
I ran the cables through the plastic liner as I didn't want rub on the inside of the frame but the plastic cable guide attached to the bottom bracket was positioned in a way that caused a sharp kink so in the end I had to remove the guide and trim it for the rear mech to function nice and smooth.
Only been out on her twice in less than favourable conditions but I can tell you she is very fast. I upgraded from a relatively standard alloy frame with carbon fork which was not much heavier. The aero lines defiantly work wonders over 20mph.
