The ONLY functional difference between Record and Chorus hubs is the oil holes in Record. The weight differences are due to a few material substitutions, but result in no functional performance differences. Therefore, the only time that Record's functionality comes into play is when you want to oil your bearings, like for a "nice weather" time trial. My take is to go Record when you get a gruppo price or other good deal and have the lust, like when buying an new bike. Otherwise, Chorus is a fine quality group at a slight weight increase, but no functional deficiencies.Argentius said:Record hubs are definitely different -- better for some applications, maybe not others.
Hey it's all good at this level. Record is a tad lighter, but really it doesn't matter unless you have to have Record. How many times has this been asked anyway?....Mosovich said:I'm going to venture on the campy side for my next bike. I record really that much different from Chorus, like DA is from Ultegra, or are they pretty close and not worth the price difference?
I did a search and didn't fine the info I wanted, so I asked. I'd ask again if I had to. Sorry to have bothered you, no one made you respond.Bocephus Jones II said:Hey it's all good at this level. Record is a tad lighter, but really it doesn't matter unless you have to have Record. How many times has this been asked anyway?....
Pretty sure Record and Chorus both use bearings, while all the others use bushings. Not that it makes much difference. Record does have the teflon coated thingamajig though.Spunout said:I just put Veloce shifters on my cross bike: Same shifting as Chorus, same parts list for the internals. Record offers 'Ultra' shifting due to a teflon coated gear...
Argentius said:Ah, perhaps the information I had was incorrect.
LBS told me when building my bike that Record hubs used a different bearing style than Chorus -- I'm not very knowledgeable about mechanics, but I think it was that they did not have sealed bearings, meaning they took more service.
Do you know if this was ever true?
Ah, perhaps the information I had was incorrect.Kerry Irons said:The ONLY functional difference between Record and Chorus hubs is the oil holes in Record. .
If anything the Record will take more service because you'll lose the little clip that goes over the oil hole and dirt will get in there. Really folks...when you're at Chorus level hubs you gotta pick some really small nits to say that Record is in any way significantly better.Argentius said:Ah, perhaps the information I had was incorrect.
