Hi there
Bought a new fork last year and a new headset, for my road bike, which was professional installed. I have about 6 cms of carbon spacers below stem and 2 cm of alloy spacers above stem.
Stem continously comes loose, you hear rattles over rough sections of road and when stopped if you lock front brake and rock bike you will have movement in headset.
I loosen 2 stem allen keys, tighten stem cap bolt,(usually about 1/4 of a turn), retighten stem allen keys, check for movement and it is perfect for about 500 kms then I have to do it all again.
I notice that the external diameter of the carbon spacers below the stem varies by about 1 mm and the widest one is directly below the stem. I also notice that I can manually rotate all of the stem spacers by hand when I have tightened the stem.
Am I not making it tight enough?
Or could the spacers be a problem?
Other thoughts?
Thanks for any input
Kevin
Other thoughts?
Kevin
