davas said:
I have a 1 in threaded fork but a normal stem (not a quill stem). What chris king headset do i need????? thank you.
... something doesn't sound right...
While you can find 1" threadless (non quill) configurations of a fork steerer, I can't recall ever seeing or hearing of running threadless stem on a threaded fork... indeed, the very nature of the materials used and their configuration (threads on a steel alloy steerer vs a star fangled or similar device inside an aluminium or carbon steerer) makes it dangerous to impossible to do so (a threaded fork would be cut to handle just the stack height of the headset used whereas a threadless fork would be cut to handle both the headset stack and the stem stack plus any additional spacers if needed). Using a threadless stem over a threaded fork steerer could cause metal fatigue (at least) and eventual catastrophic failure or (at least) the inability to adequately secure said stem!
Are U sure it's not a quill stem as well?
Anywho, go to Chris King's website to check out their alternatives. They do offer a bit of flanagalling, though not what you've described.
http://www.chrisking.com
In some instances, I've been able to convert, via their "kits" a 1" threaded to a 1" threadless or a 1 1/8" to 1"... but this is just the headset and assumes that I've got the compatible fork and stem.
Maybe I'm reading wrong or am just too sleepy.
