1 - 6 of 6 Posts
bigbill said:
I run 11 on my steel Pegoretti with around 1/32" of clearance. Like C40 says, as long as it doesn't touch, you're ok. Make sure the lock ring is properly torqued.
Am I correct in understanding it to be 1/32" between the lockring & inside face of the dropout?
· Big is relative
Yup, Big Leg Emma with ginormous chainstays and breezer style dropouts. I have to stretch a single layer rag tight to fit it in the gap. I have a similar gap between the chainstay and the 12 cog due to the angle of the chainstays.
I use Campy 11. I have HED Adrennes wheels and had to use a Shimano spacer to allow the last cog to clear the spokes. The Shimano cassette spacer pushed the lock ring against the inside of the dropout, so I currently use (until I find a thinner casette spacer) a small thin washer on the axle to spread the droputs ever so slightly just to clear. Bike is a Tarmac SL2. No contact as far as I can tell, but its REALLY close. Not the ideal situation, but I can't find any other solution.
I wish HED would get axle/cones. etc. the correct width for Campy 11....they have NOT returned two of my calls or an email regarding this issue and a better solution.
1 - 6 of 6 Posts
