1 - 10 of 10 Posts
Cog width. I'm not even remotely sure, and someone can please correct me if I'm wrong, but I would venture to guess you need a 3/32" for a Pista.
1/8" is kind of the heavier-duty/BMX standard width. Although, you can still use a 1/8" chain on a 3/32" cog (I think you'll run into some faster wearing), you can't use a 1/8" cog on a smaller chain.
I could be making a mistake though, so someone please correct me if I am.
No Mistake
Your Pista will come with an 8 speed chain and 3/32" cog. That 8 speed chain won't work on a 1/8" cog.
I have switched to a 1/8" chain which works fine with the 3/32" cog and with a 1/8" cog.
TT
1/8 is the standard width on a pista. I don't know about the Bianchis they currently sell in the US though. Using a 1/8 chain on a 3/32 cog usually is a little noisier and the engagement might not be as perfect, but it works well enough for recreational use.
A 1/8 is going to be stronger and stiffer than 3/32. there are even differences amongst 3/32 chains -- newer types built for index shifting tend to be more flexible and less desirable for a fixed gear. But like I said, 3/32 is sufficient for many riders.
Stiffer yes but not stronger*. Geared mountain bikes (3/32" chains) exert much more force on a chain with granny gears than any track sprinter could. Get a good 8 speed chain and call it a day.
By the way, I do run 1/8" chains but not because of strength - 20 years of accumulated cogs and chainrings make it cost more than it's worth to switch over to 3/32".
*Actually this is irrellivant since chain failure usually happens as the side plate delaminates from the pin which has nothing to do with the actual width of the pin.
You're probably right about about a 8sp chain being stronger than an 1/8" chain if you have a bad chain line, but I find it hard to believe that it's going to be stronger when you use it on a fixed gear. Of course it's all irrelevant since I can't imagine being able to snap either chain.... By the way, I had both 1/8 and 3/32 until 5 years ago when I went to all 3/32nd.
you're smart for switching over. I keep thinking I will but then I look at my perfectly good cogs and chainrings and decide to wait... then I buy another 1/8" cog and it only gets worse.. I have a problem and I need to stop.
As far as theoretical strength goes where (-----) is the chain pin and (^) is the cog. The 1/8" pin is longer and so the force of the cog has more leverage on the pin. A very extreme example would be: what would be easier to break a 1' dowel or a 4' dowel of equal diameter using equal force applied in the middle.
1/8"
3/32"
Theory is fun and all but riding is better so ride what you have as long as it puts a smile on your face.
Perhaps you're right, but it seems to me that the side plates and everything else on a 1/8 inch chain seem to be a lot thicker and sturdier. I'll have to contemplate this one. I kind of regret getting rid of all my 1/8 stuff, I wish I had kept them since you never know when you might build up another bike...
1 - 10 of 10 Posts
