1 - 5 of 5 Posts
It is getting cild out here already and I ride outside until it is about 3-4 degrees celsius above zero - what are your recommendations for cold weather shoes for wide feet.
I currently wear shimano R106 if that helps at all.
Lake makes some really good cold weather shoes (although I would think overkill at above freezing unless you're really sensitive to cold).
I know they make wide sizes for many of their models but not sure specifically about the cold weather specific shoes.
Good Gawd ... where do you live?
Most winter shoes are pretty roomy. I buy Shimano shoes in the wide size and my Sidi winter shoes are very roomy. Buy a half size larger. You want to have room for your feet to move around, otherwise they get cold fast. I thin sock and room is better than a thick sock and no room.
Super Moderator
FWIW, I have very wide feet, and the Lakes in "wide" sizes seem wider than Sidi winter shoes.
I have Sidis, but I sized up a couple of sizes. As others have said, you'll want extra room for socks.
1 - 5 of 5 Posts
