1 - 7 of 7 Posts
A known fact about Colnago frame sizing is that you can't assume a 54cm Trek will fit the same way as a 54cm Colnago. What's the general rule of thumb for purchasing a Colnago frame... Do you get a larger or smaller frame based on your current frame size? Or are there other guidelines that need to be factored in?
Abaddon
Does the fork rake and head tube angle matter?
I normally ride a 56 cm top tube. However, I know that the head tube angle and fork rake are more slack. Do you all think that I would go with a shorter TT length, like 55?
I've got the Colnago itch. Thanks.
Stem??
What stem length do you normally use, and is it parallel to the ground or tilted up??
I find my 54cm Colnagos handle best with 130 to 120 stem's, parallel to the ground. Factor that in with your top tube length. I wouldn't go less than 100 if possible.
C50
I currently ride a 56cm Moots Vamoots with a 110 stem, 3T Less. The Moots has a 56.3 TT. So just doing to the math, I'd be moving to a 120 - 130, depending on the stack height.
With the slacker head tube angles, I think that would work but I've never ridden one. Unfortunately, find one to test ride where I live is tough.
1 - 7 of 7 Posts
