1 - 6 of 6 Posts
Alchemy Hubs, Kinlin XR-270 rims, CW-Ray spokes, brass nipples. Front will be radially laced, 16 hole. Not sure on the rear, but likely 20 spokes. I'm pretty light at 146lbs.
What do you think?
Online Wheel Builder
I think that you have made a good selection on the parts. But I would have to suggest possibly upping the spoke count a bit. Although you might be able to get away with a 16/20, for your reassurance and durability I think that a 20/24 would be a better call. You would only be adding 40ish grams to your overall build but you would be ensuring that the occasional pothole/crack isnt going to throw that thing out of round. Going with a 16/20 sounds to me like it would be alot of maintenance in the long run.
Roland F.
I don't race, so they're just going to be ridden and ridden. I do a lot of climbing though, so weight may be an issue (probably mostly in my head). I've been riding 16 spoke front wheels for a couple years - Bontrager RaceXLights - and they are still true. I also have a set of Rolf Vector Pros bought in '98. They have many thousands of miles on them, and the front is 14 spokes. I don't think that 16 spokes in front will be a problem at all.
If it's weight thats bothering you then have you considered the XR-200 rims or at least up front in 20h it would be lighter even with 20 spokes?
l have an XR-300 24h rear and XR-200 20h up front and they have copped some serious abuse, front rim weighed 382g and built up it came in at ~540g great rims the XR series :thumbsup:
1 - 6 of 6 Posts
