1 - 5 of 5 Posts
Right now i have compact 50-34 chain ring setup. Can I use the same cranks and put on a 52-36? Need some more power without going standard 53-39.
Yes, you can. Your spider is a 110 and that is what you need for the 52/36 set up.
What cranks do you have?
Are you spinning out of your 50x11 in Illinois? I live in Colorado and can spin my 50x11 up to 50+ mph. I don't understand how a 52/36 is going to give you more power. All a 50t does is allow you to ride slower in the big ring before you need to shift to the small ring. If you're spinning out of a 50x11 in Illinois, either you have too low of a cadence, or you riding in the rare Illinois hurricane.
Dank, you should have no problem installing 52/36 on your red cranks.
1 - 5 of 5 Posts
