Aye. A 50/11 will beat a 53/12 any day.Before you go to the trouble and expense, consider whether you really need it. The difference isn't so dramatic as the terms might suggest, and with the right choice of cassette most riders can do fine with either crank setup.
gez.Compact cranks are for the elderly and the weak. Suck it up with a 53/39.
Then why not just ride a fixie?Compact cranks are for the elderly and the weak. Suck it up with a 53/39.
and only do up-hill repetition drillsThen why not just ride a fixie?
Before you go to the trouble and expense, consider whether you really need it. The difference isn't so dramatic as the terms might suggest, and with the right choice of cassette most riders can do fine with either crank setup.[/QUOTE
Thanks this helped alot. Its good to know that there are some good people out there.
Ok thanks!!!!!Yes, you'll have to add links; unless your chain was too long to begin with.
The rectangular buttons on the left and right are called shift keys. They allow you to type capital letters. Even phones have them. That way you don't come across as a lazy, self-absorbed, entitled teenager.
Three points:The only problem is that I spin out when I hit about 35 mph, but I don't go that fast very often so it's no problem. Now if I ever started doping and could smoothly spin at 300 rpm, I might have to switch back to a 53/39.![]()
Sounds like your small cog on the cassette is a 12t?I had to switch to a compact crank when I learned that the FD hanger on my new frame was too low to accommodate a standard 53/39. But I must admit that I like the range of gears on my 50/34 compact crank. The only problem is that I spin out when I hit about 35 mph, but I don't go that fast very often so it's no problem. Now if I ever started doping and could smoothly spin at 300 rpm, I might have to switch back to a 53/39.![]()
No, definitely an 11. I was just joking about the 300 rpm thing, but I do spin out at about 35 mph in my 50/11. I'm just not much of a spinner when it gets to over 100 rpm or so.Sounds like your small cog on the cassette is a 12t?
